Bear with me I'm new to the forums
Basically, my home has an unvented mains pressurised heating system - in the utility room is a Glow-worm Complheat Fuelsaver 55 boiler & upstairs in a cupboard is the Tribune Premier pressurised tank with expansion vessel.
My problem is that my systems works great when heating or hotwater (or both) are switched on from the programmer - the boiler does it's job and all rads heat up nicely - the boiler pressure gauge reads normally between 2-3.5 bars when the heating/hot water is on.
When the programmer is switched off and no heating or hot water is required to be heated - the boiler pressure gauge reduces slowly (maybe 5-10hrs) to Zero pressure instead of sitting at a nice 1bar minimum.
Due to being worried by this - I use the filler loop to pump more water in to get the pressure back up to 1 bar - but the next time the programmer switches on the heating/hotwater the gauge pressure goes above 3-3.5 bar and forces the pressure relief valve to cut-in and water to dribble out of the boiler relief pipe - once it has run it's course of heating - the pressure then gradually again reduces to 0 bar over a period of hours.
Hope the above is making sense so far? - I have checked the system for obvious signs of leaks & found nothing - the pipes are not buried under the floor downstairs and run along inside the walls or under the upstairs floorboards - and no damp patches have been spotted over the weeks. I have also checked all rad valves and see no obvious leakage signs.
I can only assume that when the system is not being used - maybe the pressure in the expansion vessle needs to be looked at and is low hence not holding the normal pressure at 1 bar minimum.
As I'm no expert - I'm just guessing at the above - Can anyone out there please please give me some possible fault advice so I can get an expert in to fix it.
Many thanks in advance for your guidance
