faulty heater in fiesta
11 Nov 2008
Yorkshire
hi, can anyone help me with my heatin in my 96 fiesta. the heating was working fine til last nite then it suddenly started blowing only cold air. is this an easy fix or an expensive garage do ?? [/b]
It depends what has gone wrong. It could be a flap stuck in the ventillation only allowing the cold air side in, it may be a blockage in the coolant loop to the heater matrix so no heat is getting to it, it may be a more serious problem with the cooling loop on your car.
Have you checked the coolant water level?
minnie12";p="1052396 said:
hi, can anyone help me with my heatin in my 96 fiesta. the heating was working fine til last nite then it suddenly started blowing only cold air. is this an easy fix or an expensive garage do ?? [/b][/quote
sounds like a heater valve
Heater valve I would imagine too.
not done one on a fiesta, but did have the fun of fitting one to a ford Ka, can only imagine its as awkward to get to.
Very common fault according to the scrapyard I get the parts from, he sells lots of these valves.
