Hi
I did a search first on this forum to see if I could find the information relating to my request but nothing seems to fit what I am going to ask.
I am looking for advice on whether I can add Fernox inhibitor and cleaner into my central heating system.
Its an LPG system boiler with a Heatrae Sadia Megaflow cylinder downstairs (i.e. both at the same floor level). As far as I can possibly see, there are no header tanks whatsoever connected to the cylinder and the loft space is restricted and currently has no access. The instructions that came with the megaflow explain how to re-charge the separating bubble so I'm thinking its like a primatic setup? In which case, according to the instructions of the Fernox stuff, it could be an indirect setup and therefore I should not use Fernox in it? I am even remotely close with that hypothesis? To add to this, on the side of the Megaflow cyclinder there is a plastic cover with a single cable coming from it and the cover sticker mentions that this is where the Indirect Thermal Controls are? It is fitted with a Magnaclean magnet device which is cleaned regularly.
Any structured advice appreciated. Thanks
