Hi there,
My Uncle has had the above boiler in his surgery for the past 7 years or so, it has generally been reliable but now that there is some work being done to the surgery so they are considering doing one of the following:
1. Replace boiler, replace undersized radiators (there are about 4 of these), replace TRV's and of of course get the system flushed etc, replace current Drayton thermostat with a new Honeywell CM927.
2. Keep current boiler, get undersized radiators replaced, get thermostat replaced, get system flushed and replace any faulty TRV's.
Which one is the better option?
The reason the thermostat is going to be replaced is because it can't regulate the temperature very well and the temperature swings from hot to cold.
Note:
The boiler has to be on 82C or else the surgery will not get warm, there is no space for a cylinder and hot water requirements are not very high.
Thanks for your help.
Note:
