I’m in the process of fitting new, deeper windowsills in a bay so that shutters can be fitted on top. The old sills had been bedded on a very deep bed of silicone, approx 15mm deep. I need the replacement sill to be at the same height as the old sills as the shutters have been made to fit the height of the old sill. Unfortunately, I didn’t know how much silicone was under the sill, and i now need to pack up/fill under the new sills by around 15-20mm and fill the gap behind the plaster to give the sill something solid to sit on.
What should I use as the filler material? I’m thinking mortar with gripfill and screws to secure the sills and easifil to blend it into the plaster. Any better suggestions? I’m assuming window fitters come across this problem regularly.
