hi guys,
just in the process of filling in some of the wholes left by rawl plugs and the like.
even thought I have filled them and sanded down - the paper from the plasterboard is proud of the surface..
any tips for getting a good finish? if I paint it now there will be tell-tale raise dcircular areas...
I was thinking abou taking a fresh sharp razor blade and cutting the plasterboard paper in a slightly larger diameter around the hole to get rid of a torn edge, and then fill in the new recess - or is there a tried and tested method that the pros use?
