Filling Small Gaps Near Pipes
16 Oct 2009
Derbyshire
Hi all,
I have a few pipes that go though the celling from some rooms and some have big gaps in. Some ar eth size of my fingers next to the pipe and i wanted to know how is it best to fill these. 1 room has allready been painted on the celling and others have not yet.
Will it cause any problems with the pipes if i fill the area.
ALso what filler is best for this
Chris
Caulk's no good for big gaps and it goes green with contact with copper. Pollyfilla will do.
OK cheers for that. They are copper pipes so i will use poly filler. When the pipe get hot and expand will the filler not crack can anyone answer.
Also is it ok to paint over filler
Chris
If the pipe is painted first it wont make anything go green. Ive used caulk in that location for ages with no probs. Yes you can use polyfilla also but any hard filler will crack as it touches the pipe because it will expand with the heat.
So do i use Caulk near the pipes or not as it sounds like people say it go's green and others say it dont with contact with copper
Chris
New copper pipes should be painted with calcium plumbate primer before any other paint. Most people will just use undercoat and gloss. Will probably work ok. If the pipes have any kind of paint on them then they wont make things go green. You can use hard filler like polyfiller, might crack near to the pipe as it expands and contracts. You can also use caulking and both will be ok when painted up.
Hi all,
Chris
ima painter & seen caulk being used so many times DONT USE CAULK! caulk does perrish and isnt a nice finish what u do is get a piece of paper tape and some ready mixed filler
place the paper tape on a piec of cardboad and skim over the back off the paper tape[the side thats getn stuck to the wall]
then place the side with the filler on the wall over the hole,since the filler is all over the paper tape it goes solid where as just round the hole it would be able to pop thru
then all u do is a couple of skims of filler on top. sand and paint :D nice clean finish :) and easy!!
Can i use caulk around skirting board gaps and then paint over or is it best to paint it first then fill in
Chris
On previously painted wood fill it then paint over. On raw timber prime it first then caulk or it wont stick to the timber.
