I have a Baxi solo boiler, this is above and goes to the upstairs where the cylinder and pump are. I want to clean out the filter on the left. Can anyone tell me how to isolate this to do it or is there another way?
Want to put money on that?won’t have any trouble with the valve leaking.
I'm worried that turning the valve may cause it to start leaking. What would I need to isolate if I needed to repair or replace the filter please?
Then, it should only be a case of opening the valve at the bottom to drain it, no?It is a sediment trap.
It has a labyrinth so that water does not spin around except at the top, the rest is still so heavy particles sink to the bottom. So it is better at catching gritty or spiky bits, than fine sludge.
