- Joined
- 20 Apr 2014
- Messages
- 2,467
- Reaction score
- 0
- Country
Please can you advise me. My friend and I are trying to figure out something we cannot find in the regs. We both have an electrical background.
We are trying to find out why you cannot put more than one circuit in a fuseway. What started it was when we inspected a kitchen and found three items (pretend they are 3 hobs for now to keep it simple)all fed from one circuit as a radial. Each one has the correct cable (2.5mm) and the fuse is 20Amp. If one item goes faulty the fuse will blow (obviously all 3 items will then be off)so it works safely as the cable is right and so is the fuse. Whats wrong with it? Taking it to the extreme what stops you putting ten radials in one circuit apart from common sense, ie a blown fuse would mean the loss of ten items until fuse replacement? Basically we would also like to know how many circuits can be fed from one way. I believe you can run one spur from the ring, actually from the fuse way which would give you 3 cables connected to the way. What is the limit?
Any help would be appreciated.
Yours faithfully
Demo Zambourides
Yours faithfully
Demo Zambourides
