fire doors
23 Mar 2005
hi all, had the loft partially converted last year.....got to hang a few 1/2 Hr fire doors(heavy things aint they)....gonna have to cut them down...do i need to then router the edges back in to refit the plastic strip? also the door casings have the routed slot out,do they needs the fire strips fitting or is it just one or the other?
cheers
magico
I'm not sure if you're allow to cut the fire door down, best to ring the manufacter first for advice. They should fit into the standard size door frame.
why shouldn`t i be able to cut them to size m8?There solid doors mate
I didn't say you could or not :!:
I thinking the way the wax seal is bedded into the door and I'm not sure if you're allow to tamper them with.
the seals just push in or out m8,i saw a site on net where you can buy rolls of the stuff.
Any1 else got any ideas?
quite a bit mate,sides mainly but some top and bottom
Yes but you're still not telling me the internal sizes of the door frame :cry:
my mate says that you carnt partially convict a loft- its all or nothing and if you chop the door in half then itll invalidate the fire certification for the door - fire doors should come as sets with the frame unless test info says different
This is why I'm waiting to see what the internal frame sizes is, I have fitted many fire doors for old people rest home completed with frame plus the gap round the door must not be more than 2mm for the wax seal to melt to make it air tight. I know I called it wax seal but the real name is Fireplug Intumescent Strips.
