I have a fairly old ,but perfectly working gravity pumped system, and would like to fit a 2 way valve to control the hot water cylinder from becoming too hot.
The cylinder is contained in the upstairs airing cupboard, and I intend fitting the valve unit in the short length of horizontal 22mm tube to the internal coil before it right angles down through the ceiling to the kitchen mounted condensing conventional boiler,
As I need to cut this piece of tubing to fit the valve would there be any water in it if the system is switched off and had not been heated up for two days.
Thanks vectraguy
Thanks vectraguy
