Hi I want to fit an rcd to the current consumer unit it has mcbs but no rcd protection would this be notifiable or minor work?
I'm trying to get my head around that. Are you suggesting that, in general, inserting an RCD into an existing circuit results in the creation of a 'new circuit', hence notifiable?Would depend on how it was installed, if external to the board, which could incorporate a new circuit to the board then yes.
I'm still not totally clear as to what you're saying. Do you think that simply inserting an RCD between meter and CU would constitute 'adding a new circuit'?I am say if a new circuit was fitted at the distribution side, it could!
That's a non sequitur - some minor work is notifiable, some is not. Some non-minor work is not notifiable, some is. Some notifiable work is minor work, some is not. Some non-notifiable work is minor work, some is not.Hi I want to fit an rcd to the current consumer unit it has mcbs but no rcd protection would this be notifiable or minor work?
As you say, "arguably". However, one hopes that common sense would prevail. If the choice is between leaving an installation with no RCD protection and protecting the whole installation with a single RCD, I'd happily argue with anyone that the latter is safer (certainly no less safe, even if one is an 'RCD sceptic'), and hence more in keeping with the spirit of the Wiring Regulations.Adding 1 RCD arguably contravenes the wiring regulations.
As you say, it's a common concept, but, I would suggest, not a very convincing one. When one is talking about safety, 'better than it was' is quite obviously desirable, even if not 'as good as it could be' or 'as good as required by current regs'. To fail to improve the safety of an electrical installation 'because it would not be compliant with current regs' would, to my mind, be irresponsible. I can't quite see how such an issue could ever come to be tested in a Court but, if it were, I hope that the Court would see that 'increased safety' (when there was no obligation to increase safety) outweighed 'full compliance with current regs'.True, but work done today should comply with today's regulations. It's a common concept, which applies to all sorts of areas - no compulsion to bring things up to date, but if you do, then simply "better that it was" may not be good enough.
That's not a foregone conclusion, since it may be possible to change the 'main' switch to an RCD.Its going to have to be before the consumer unit because there is no more room on the board to fit it in so im guessing this would be notifiable to building control?
You may be unconvinced by fact - there is precious little anyone can do about that.As you say, it's a common concept, but, I would suggest, not a very convincing one.
Be that as it may, if the regulations require a particular standard then the regulations require a particular standard.When one is talking about safety, 'better than it was' is quite obviously desirable, even if not 'as good as it could be' or 'as good as required by current regs'.
You would have to take a very narrow view of "responsibility" to not see that it is possible to improve safety and comply with the current regulations.To fail to improve the safety of an electrical installation 'because it would not be compliant with current regs' would, to my mind, be irresponsible.
Nor can I, but if we assume the default that in the absence of special, expert-backed pleading for an alternative, compliance with Part P requires compliance with BS 7671, then a court would have little room for manœuvre.I can't quite see how such an issue could ever come to be tested in a Court but, if it were, I hope that the Court would see that 'increased safety' (when there was no obligation to increase safety) outweighed 'full compliance with current regs'.
Be that as it may, it is arguably a contravention of the Wiring Regulations to have a single RCD for the whole installation.In this case, it is (IMO) particularly 'silly', since the failure of a single RCD to comply with current regs is essentially just in relation to matters of usually minor 'inconvenience'. Although one can talk about people falling off ladders or down stairs, or pouring boiling oil over themselves as a result of lighting failure due to a single RCD, I would suggest that the risk of death or serious injury due to having a single RCD (which was perfectly acceptable/normal in the past) is 'vanishingly small', and greatly outweighed by the protection provided by that single RCD.
Why not ask an electrician?Its going to have to be before the consumer unit because there is no more room on the board to fit it in so im guessing this would be notifiable to building control?
Of course it's possible, but it's also possible to improve safety without fully complying with current regulations. To my mind, the crucial point is that, in relation to the sort of things we're talking about, there is no requirement to improve safety at all, let alone to bring an installation up to current regs. That being the case, my version of common sense suggests that it should be permissible to voluntarily introduce improvements in safety even if what one ends up with is not compliant with current regs.You would have to take a very narrow view of "responsibility" to not see that it is possible to improve safety and comply with the current regulations.
