Fitting kitchen tap - almost there but a small problem
C
charliebean
I bought a replacement monobloc tap for the kitchen as the old one was a bit tatty and dripping.
I managed to get the old push fit connectors off (though it wasnt that easy - I'm not that strong), they were brass ones with little sleeves you have to push in. I used a cheap tool from screwfix to get them off.
Fitted the new tap and pipes, but the cold one leaks. I presume the seal is damaged a bit on the push fit connector, though one thing i noticed was that when originally fitted (new house, 6 years old) the pipe length was only just long enough to sit in the connector just enough, it really ought to be a half inch longer I think. But regardless, it's dipping.
So, I bought some replacement push fit bits: http://www.screwfix.com/p/conex-cuprofit-straight-coupling-15mm/60835 (no collars on these) but they are an inch shorter than the old ones, so there is not enough pipe to use these ones and connect the two halves. I can't find any longer ones on screwfix, the sheds, or plumbase. That leaves me a bit stumped.
Aprreciate any help.
or cut them back and try something like Toolstation 13532 if you have room.
These would be ideal, and Wikes which is local to me have some: http://www.wickes.co.uk/invt/227360
Assuming they are suitable for drinking water, the only thing is I have now removed the old fittings so all I have is the simple copper pipe coming out of the wall at a 90 degree angle, and the copper pipe coming out the tap. Will I be able to get away without an elbow using these flex pipes? I'm guessing it would be likely to kink.
On that basis, I think I'm going to buy this:
http://www.screwfix.com/p/speedfit-flex-tap-connector-15mm-x-x-300mm-pack-of-2/62136
and this:
http://www.screwfix.com/p/conex-male-elbow-402-15mm-x/76710
Hopefully that'll do it.
Flexis have to have smooth, slow curves, not be sharply bent.
Picture would be helpful.
