With an mdf bath panel as they usually have a plinth, do you cut a rebate into the baton on the side walls? Or just two small bits of baton; with the plinth bit set back 10mm and drilled into wall.
Do you screw into the front of panel into bottom and side batons through the front then hide screw heads with those plastic thingees?
