I'm about to tank the walls around our quadrant shower tray using a Mapei Shower Waterproofing Kit. Here is the tray.
The kit came with a 10m roll of waterproof tape, I've cut a small piece off the roll for use in the photographs and I've temporarily attached it to the wall with some bits of blue masking tape.
The instructions suggest the tape slightly overlaps the tray like this.
I am fine doing this until it comes to the corner, because you end up with a ruck in the tape like this
The only idea I've had is to cut a small section from the waterproof tape like this
So you end up with the corner like this
However it means there is some overlap of the tape.
So how do you guys deal with this issue? Is there a better solution?
Thanks in advance.
Thanks in advance.
