Should of employed the services of someone who knows what they are doing.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
3 day’s now.
3 day’s now.
That was me, sounds like you've tried everything else, the only way to be sure is to trySomeone did suggest multiple fibre washers but not sure if that will bear fruit..
modified jam jar technique - Put it in the freezer overnight. Then get a blow torch on the outer part.
Hey john , you may need to ammend this....wouldn't this result in the freezer going up in smoke !!.regards Terry
You are not tighten ing the nut up enough against the fibre washer / mini. Think about it ,the only thing keeping the threaded fitting "tight" is the PTFE. Once you get a start it should be really easy to unscrew it off.
