Hi chaps..
Yet another question for the assembled. I'd like to wall mount our 46" lcd, picked up the bracket yesterday from Screwfix but just couldn't get my head around which set of fixings to go with it.
It's being mounted on a brick chimney breast (not used/filled in) that has been drylined with 2x1 battens and 12.5mm plasterboard. I can easily remove the plasterboard where I want to mount it (not skimmed yet) and I'm planning to put some more 2x1 inline with the bracket to spread the load.
So what would you recommend for fixing thru: Plasterboard > 2x1 Timber > Brick?
Did see http://www.screwfix.com/prods/41972...ischer-A2-Sleeve-Anchors-10-x-100mm-Pack-of-5 but there's so many others to choose from last thing I want to do is pick the wrong one and take a gamble it'll stay up.
I've also seen these recommended M-Form Bolts but I'll be damned it I can find them on screwfix unless they are a combination of frame fixers (for the wall plug) and then matching coach bolts? Or can these be bought somewhere else?
Many thanks!
Rob
Many thanks!
Rob
