I am getting my information from being a member of Certass and Thermal Ratings Register .... may I ask where you are getting yours from?
Out of my in-tray
May I ask what you do Woody, as I am trying to work out if the info CPS schemes give out is misleading......I am getting my information from being a member of Certass and Thermal Ratings Register .... may I ask where you are getting yours from?
Out of my in-tray
I understand that fully...that was supposed to be one of the reasons for the Mtc card...When you see FENSA registered firms routinely fit inappropriate frames or glazing, or replace timber frames (fire resistance), with plastic frames (no fire resistance), or replace load bearing frames with non load bearing frames, or fail to install lintels where required, or carry out work that should be subject to a separate b/regs application but do not make that application, then it makes you wonder exactly what FENSA is for.
PVC windows are self extinguishing unlike timber so I think the fire resistance comment is a little unfair but I agree with the rest of your comments.
