Flat warm roof fixing insulation and top board
25 Aug 2016
I'm building a flat warm roof, got the timbers and firrings on with 11mm osb glued and screwed on top, next will be a layer of vapour barrier followed by 120mm insulation, 18mm osb then the membrane.
What do I use for securing the insulation and 18mm osb to the roof? Do I get some type of 150mm screw and screw down through the osb, insulation and vapour barrier into the 11mm osb?
Chris
