Hi all,
So for the past two days I have experience flickering lights throughout the house. It is not constant but happens enough to notice it and it literally does it as a one off blink every so often (which is completely sporadically rather than in a particular pattern).
No new lighting fixtures or electrical appliances have been added inside the house. At first I thought it was the ring for the ground floor lighting circuit but it actually happens throughout the house. Electrical appliances are not affected, however when I connected an plug powered uplighter, it also does the same.
Am I right in thinking this is likely to be a power line issue or could a faulty electric item cause this (even if it is not powered and is switched off?).
