float valves
5 Dec 2012
Hi all,
I am working on a project for a boarding school in a developing country in the Pacific. I am trying to install a simple washboard type aerator above a tank (to try to reduce H2S smell). The water will be pumped into the aerator, flow through the aerator as through a waterfall, then enter the tank. I want to put a float valve in the tank to stop the pump when the tank is full. However the inflow will be into the aerator, which will be about 1.2m above the tank and will be a separate unit. I do not have any power available (the pump is about a km away so I cannot use its power source). Any suggestions you may have as to the float situation will be most gratefully received!!
This post should be relocated in the plumbing forum.
However, you will have to provide more information, and if possible, a section diagram of your proposed arrangement.
