Hi guys,
Is there a preferred type of cable for running up inside a floodlight column.
The posts will be about 60' high and two 2kW (415v) fittings mounted on a cross arm at the top.
Thanks guys,
I do not think there is any provision for cable support. I have seen cable with a built in support wire for pendant controls etc. and wondered about this type of cable for the column situation.
This is not a typical column, and is bound to have cabling provision!
It is rare to spec just two 415v fittings. If you just have one or two fittings you would usually go with 240v fittings. 3 or more fittings would lead you to 415v fittings.
The current posts are 60' and about 30 yrs old. Although I am not sure of the height of the new ones, the "worst case" will be like for like (height)
The old thorn 1500w single phase fittings have been replaced over the years with thorn mundial 2kw units which provide an adequate light. Four posts, 8 lamps.
tiewraping the cable onto a rope or wire rope every 2 foot or so as you feed both in, and then anchoring the rope / wire at the top will provide stress release.. especially if you leave a little slack in the wire as you tie it..
