Floor joists supporting roof load?
17 Jan 2010
In a loft conversion where new larger floor joists span from eaves to centre spine wall to eaves, is it possible to substitute roof purlins (& supports) with a structural stud wall which is built off these new floor joists rather than off a steel beam, if the floor joists are of a larger S.E. calculated size (than those stated in span tables which obviously only consider floor loadings)?
Im just considering an easier installation method (possibly) than inserting a large/long/heavy steel (with awkward access), before calling back the S.E. to recalc.
Thanks in advance
Yes, may not be cheaper though. Although if timber is your medium then could be an option.
As far as i know (since having this done myself) Your new larger floor joists will have to installed on or into new steel (RSJ's) in order to remove the purlns & supports. Sounds like a "yes" from what i read. You could check with a surveyor/architect tho..to be sure
Thanks in advance
