hey I have a hot tap that starts to run when turned on then sometimes stops and has to be screwed shut again and opened to get working again what could be going on here?
is a screw down type mixer tap. A tap head to screw down on both hot and cold side. Don't think will be an air lock as its sealed system, combi boiler. Hasn't been drained down, just started over last couple of weeks,
If you feel confident enough to dismantle the tap, you'll find the rubber tap washer has spread, and preventing the tap jumper from releasing fully.
John
the other taps are ok no its run off a combi boiler. Could I just replace the head section of the hot side of the tap. I think there call reviver kits?
