I just thought "to what" didn't sound right in that case and a verb that didn't need "to" would be better.Nothing - but what made you say that the version with 'refers' was 'not right'?
That might be true of the 1199mm one (although they also do a 1200mm one!), but the others are all way off either the with-pins or without-pins dimensions of the traditional Imperial sizes - which suggests to me that they probably won't fit in a standard fitting.Perhaps Sylvania were just measuring really accurately!
Not me - the longest I've seen is 8'.Talking of odd sizes, in one of my 1930s magazines they briefly mention 9' and 12' fluorescent tubes! Has anyone come across tubes of these sizes?
I agree that it doesn't "sound right" ('awkward') but I think it's grammatically correct.I just thought "to what" didn't sound right in that case ...and a verb that didn't need "to" would be better.
Well, yes, but you're surely merely saying that, in general, any contrived wording to avoid having a preposition at the end of a sentence sounds wrong/awkward (even if grammatically correct) - if you substitute a verb that doesn't require a preposition, then the problem obviously goes away!!... and a verb that didn't need "to" would be better.
P.S. Googling indicates that 10' ones are still available, but a quick look didn't find any 12' ones.Talking of odd sizes, in one of my 1930s magazines they briefly mention 9' and 12' fluorescent tubes! Has anyone come across tubes of these sizes?
Yes.I agree that it doesn't "sound right" ('awkward') but I think it's grammatically correct.I just thought "to what" didn't sound right in that case ...and a verb that didn't need "to" would be better.
It's not really contrived; merely not done correctly in the first place.Well, yes, but you're surely merely saying that, in general, any contrived wording to avoid having a preposition at the end of a sentence sounds wrong/awkward (even if grammatically correct)... and a verb that didn't need "to" would be better.
Does that mean there is something 'wrong' or 'odd' with verbs which do need a preposition? I don't know.- if you substitute a verb that doesn't require a preposition, then the problem obviously goes away!!
Clearly not 'wrong', if it is grammatically correct - and 'odd' (or 'awkward') is essentially in the eyes of the beholders.Does that mean there is something 'wrong' or 'odd' with verbs which do need a preposition? I don't know.- if you substitute a verb that doesn't require a preposition, then the problem obviously goes away!!
Thanks. OK, that explains where Sylvania's 549, 1149 and 1449mm came from - but is that perhaps specific to T5, which is a somewhat different animal to T8/T12?From the GE Lighting LongLast T5 data sheet.......
The pins lengths do vary a little, but all the 5 ft or 1500mm ones I buy now are very close to (sometimes exactly) 5 ft (1524mm) including pins (dimension C in the GE datasheet). Since, at least in my experience, they still fit in very old fittings, I get the impression that the tube length (without pins) has always been very close to 1500mm (59.06").But I don't think the 5 foot tube was ever 5 foot long, the total fitting may have been 5 foot, with the covers etc. But not the tube.
My point is that I don't really see much of a difference - in both cases you mention, language has come to be used (and accepted) which would previously have been regarded as incorrect/'wrong'.There is a difference in 'evolving' - not using 'thee' and 'thou' (not sure how 'you' replaced both) - and redefining words because most people use them wrongly as is the case with 'literally' according to the OED.
Yes, because the great majority of English speakers consider it wrong, and don't say it. However, if a high proportion of people came to use that language (and regard it as 'normal'/'correct'), then it would be too late, and arguably inappropriate, to attempt to 'discourage' that evolution.If people slovenly use, for example, "we was", should it not be discouraged?
Indeed they do. They also say things like "he gave it to I".People in Devon may say "us is"; ...
This is very different. You are now talking about regional dialects/variations which some people passionately want to preserve. I also suspect that in some such cases, those 'regional oddities' are, in fact, the way the English language once was - and the rest of us have (incorrectly') changed how we use those words!...should that become the correct way? Who is deciding?
That is Somerset.Indeed they do. They also say things like "he gave it to I".
It must just be excluding and including pins if they're the same overall length. Flourescent tubes are about the only thing I use imperial for. I got asked to 1st fix some wall lights at 6ft the other day, had to go find a tape measure that had feet and inches on it
I understand that, but you will also understand that some of us are of a generation for which exactly the opposite was true - so, correspondingly, I struggle to visualise (or think about) most things in metric measurements.As with everything, I struggle to visualise stuff in imperial measurements. I'm of a generation where everything was taught in metric, and very little heed was paid to imperial conversion.
Evolution of almost everything is pretty inevitable - whether in terms of language, dress, diet, music, art, 'opportunities', technology or whatever. A Victorian coming back to life in 2016 would find a vast number of things which were unfamilar/ unrecognisiable, a good few of which they would regard (by Victorian standards) as 'wrong', or even 'unacceptable'.I accept all you say and only introduced the (if they were) dialects as examples of 'wrong' speech (we was) which could become the norm. From what you say, the process is inevitable and today hastened by the instant media.
Don't get me wrong. I shudder as much as anyone else when I see/hear individuals making mistakes with language through ignorance (like your "we was") - and, if it seems possible to do it without getting punched (or worse), I agree that such errors should be pointed out, in the hope that the individual will learn, and correct his/her error.So, instead of encouraging everyone to speak and write properly those who do will be dragged down by the majority.
