Not too tricky...
First, remove the door trim panel (leave the window up). Pull back the weather shield to expose the inside of the handle. Look at the back side of the door handle, you will see two brass colored screws with a torx head. Remove the screws.
Now on the outside pop off the sort of triangular shaped plastic cover (on the drivers door this would be the piece that covers the key hole). Now with the handle in the closed position slide it to the rear (where you just removed the cover) and pull it away from the door. The hardest part of this job is not losing the screws inside the door!
Good luck,
