Thanks for being interested, I've got one in the loft.
I'm sure its an indirect fortic primatic works kindof similar to a diving bell
I used to have a diagram explaining how this worked (ex mech engineer must have diagrams) which gave me the bottle to work on it, now I've lost it.
I've done a few hot water tap change jobs but know this doesn't require a full drain.
I now need to remove rads and am sure this does.
Although I did a full tank drain 16 years ago when a carpet fitter nailed a 22mm feed pipe I now keep reading how this is fraught with refill difficulty and difficulty 16 years later is an unwelcome guest.
I honestly don't remember it being too hard but them I didn't drain the rads, only the tank.
Is there an easier way to remove rads without a drain down, I read about bunging the feed pipe at the bottom of feed tank with blue tack and this stops the water draining.
Any help Any diagrams AnyOne
