freezing pipes
8 Nov 2006
Bristol
A large pipe run in my house is through a roof space. The pipes are wrapped in some kind of insulation wrap and i have fitted new foam insulation where none was previously. Trouble is all these pipes runs are in a tight corner between ceiling and wall so normal pipe lagging can't be applied. Can loft insuation be tucked into the corner to help or is there something else i can lay on the pipes to help them not freeze?
They're feeding mains cold and tank fed hot services. It's the cold that freezes normally and when flushing the toilet it coughs and judders until the water starts flowing so it's not freezing solid. (The toilet is the last run for this pipe and before it is a T for a basin)
There are these devices (cant remember the name) and you attach it to the pipe and it sends a low electrical current through the pipework which takes the chill off the pipes to prevent freezing.
You will have to google them though, I don't know the price range either sorry.
