Full Bore connection for water softener
11 Dec 2019
I wish to replace an exisiting water softener with a new replacement.
My Kinetico 2020c HE has just been read its last rites. Since it was installed I've changed to a combi boiler and the flow has never really been high enough.
I've also discovered that an isolating ball valve in the mains run, and one of the washing machine connections was also not closing or opening fully. I've now replaced the ball valve with a full bore fitting and the (unsoftened) water pressure is much improved, plus I've got some 22mm flexible hoses to run to the new high-flow softener.
However, I cannot find a fitting that will give me a 15mm to 3/4" tee in anything but what looks like narrow bore, which will compromise the water flow. Does such a fitting exist?
If such a product doesn't exist then I'll put a full bore isolating valve on a regular tee, but I'd prefer a one-stop solution.
Regards
Tet
