Hello all, I work mainly in the Air Con industry, the general wiring make up of an AC installation is, DB to External Compressor then Compressor to Internal Evaporator using a control cable. Since working in this industry I have always been concerned with the control cable. The current draw of the compressor can be high and therefore a large cable from DB to compressor is usually installed. But from Compressor to Evaporator the current draw is usually quite small so you could use a lower rated cable, however it will only be protected by the breaker in the DB, which is inevitably large to cope with the compressor. I would like to start fusing down so we can use a lower capacity cable from Compressor to evaporator. I was thinking a bit of din rail mounted in the compressor and an MCB mounted on that would be ok,. Any objections? The compressors are situated outside and although IP protected, there is little protection from cold and damp any ojections here?. Alternatively an inline cartridge fuse could be used to fuse down again any objections.
Thanks for any advice given .
