When installing a boiler, ( for this purpose a combi) I usually bring the feed from a switched spur, though if a socket is near I,ll use that.
Now the question is if using a socket should the socket be switched or un-switched.
The thinking is an unswitched socket issolation requires the plug removing. with a switched socket the switch is thrown but is it poss voltage can still be there through a fault with nuetral. with a fused spur all is issoed aint it.
Cheers Sparks,![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers Sparks,
