Is the socket on a ring final, a spur from a ring final or a radial?
What size is the cabling and size of the protective device?
What type of cable will you be using? Twin and earth?
Will it be buried in plaster or a stud wall less than 50mm from the surface?
Is the socket your contemplating taking the supply from protected by a 30mA RCD?
Thanks for your reply
Socket is on spur from ring final. Socket I intend to use has two sets of wire going into it.
Will be using twin and earth.
It will be in stud wall less than 50mm from surface.
Yes socket is protected by 30m RCD.
