galvanised mains pipe plastic connection
12 Feb 2006
I need to a length of my galvanised water main with poly pipe to lower the level (at the moment its above ground) Is this straightforward? Can I just turn the water off, hacksaw through and fit a compresion joint of some sort to join the plastic pipe? I guess it must be an imperial size pipe, about 1 inch dia.
No you cannot.
You could cut the pipe and unscrew it at a join, or buy a Philmac universal coupler.
And don't forget the insert for the mdpe.
you could isolate 3/4" galv pipe, cut, and fit a PRIMOFIT 3/4" x 22mm adaptor
then work off the 22mm side in mdpe or whatever material yakes yer fancy
the PRIMOFIT slips over the 3/4" galv pipe and tightens on like a compression fitting
you could isolate 1" galv pipe, cut, and fit a PRIMOFIT 1" x 28mm adaptor
then work off the 28mm side in mdpe or whatever material yakes yer fancy
the PRIMOFIT slips over the 1" galv pipe and tightens on like a compression fitting
It won't be 1" Glasgowgas. 3/4" maybe :idea:
oops small vodka mistake, will edit
should i hit the thanks button to give yer counts a boost?? :evil: :evil:
no worse than a large southern comfort mistake
old boy in the work necks stuff called "Big Knob" from Aldi or Lidl
100% blow yer nut aff!!
southern comfort is fer shandy drinking p oofs!
you want to be careful about sleeping rough in openback trucks kev someones already nicked yer shirt,shoes and socks :LOL: :LOL:
Thanks for the advice. I'd better get a pint of that stuff!
