Gap under external door.
3 May 2021
Hi all.
Our external door has a draft on one side, this is due to the seals on the underside of the door being damaged when the previous owners let the door drop. I've asked a door parts site for advice, but they think the part fitted is now obsolete.
My question is, where can I find a T gasket that would fit the 4mm slot (been searching all day) or possibly a U or L shaped attachment that I could fit on. Images of current one attached.
I presume you want 4mm wide (not height) brush pile?
Think I’ve had 5mm before, (eBay) think it would be a faff to trim a mm off.
might be easier to replace the aluminium threshold strip on the underside of the door, to accommodate a wider, easier to buy pile.
