Garage joist strengthening and general questions
26 Feb 2013
Oxford
Hi All,
Looking to put plasterboards on the garage ceiling and some down lighters, not a massive amount of heavy stuff is currently stored there (primarily boxes etc) but I think it would be a good idea to reinforce (existing joint size approx 6mx7.5cmx 4cm distance apart approx 56cm)
The way that I am thinking of doing it as follows and my questions are below
  • Cable for down lighters.
  • Strengthen existing joists.
  • Loft boards for storage.
  • Add insulation.
  • Screw plasterboard
  • Connect lights
  • Add loft hatch and ladder
  • Plastering.
  • Painting
Looking for advice below on the following steps please:
That's how the current boards are (pieces of timbers that don't go all the way so the middle bit is empty for access)
What would you recommend to put for loft boards ?
Happy with the current material however as I said it doesn't go across.
But options that I am thinking
A)Timber board
https://www.wickes.co.uk/Wickes-PTG...gclsrc=aw.ds&dclid=CN_Yo6Gejd0CFfgN0wodWdgFcQ
B) Chip board
https://www.wickes.co.uk/Wickes-Chi...gclsrc=aw.ds&dclid=CMnU79Cejd0CFXYE0wodmwcGVg
C) Leave as is and just put pieces of timber in between the joists (battoning) and add extra pieces of ply as required
Or any other advice?
Regarding strengthening existing joists I found the following ways :
1) Sistering - problem with that is that existing joists are more than 6 meters long so it had to be a special order I guess and not the most cost effective way
2)Joist braces -seem the most cost effective way but not sure how effective it is ?
3)Any other suggestions
Also there are pieces of timber that travel laterally at the top and bottom of the garage and was wondering if they server a purpose or they can be removed (it would be harder to board it along with them in place)
Picture below:
Bottom:
Top:
Finally any other recommendations in the order of tasks or anything else would be very welcome .
