I have a garage requiring power . Firstly I have a 12 way CU with spare mcbs then from there my cable run to the rear of the property is unhindered , so can use any size or type of cable i want , however this where it gets problematic . The route the cable needs to take from the rear of the house to the garage is a blue poly pipe buried in the concrete this pipe has an internal diameter of 14mm. So my question is what cable to use on this run . would i be alright with 4mm . I realise in an ideal world this would be armoured but the pipe restricts me from using that The garage is eagerly awaiting a supply ,it has a garage CU supplying one power ring with 5 sockets and on lighting circuit.that i have just installed . No heating will be required in the garage .
Distance from Main CU to rear of property 20m
Distance from rear of property to Garage CU 7m
Thank you for your time in reading this
