Gas cooker brackets?
19 Apr 2008
Suffolk
Before you all jump down my throat for daring to ask about gas related stuff :) , how do the regs get interpreted these days, after doing up my kitchen I looked into maybe getting a new cooker, my old cooker has a slot for the stability bracket, all the new cookers I have looked at no longer have a slot for that bracket, they now have a safety chain basically welded/bolted straight to the unit and no way of fitting a bracket. I take it just a chain must pass the regs then? I've read that as long as one or the other is fitted it's classed as O.K or are these new cookers not up to the regs, my old cooker actually has both in use, bracket and chain
Thank you, I just wanted to be sure, If I go ahead and get a new cooker bought anf fitted, I'll have to re-tile where the old bracket was, I basically looked at a few to see if they all had a slot in an industry standard defined space, with gas safety regs changing so often it made me wonder, a chain alone doesn't stop that small initial tip like a braket would :)
