Hi any help or pointers to reference materials greatly appreciated.
Background.
We were left a piece of land by my wife's farther, got planning permission for 3 Holiday cabins. Tendered the job and with no interest credible interest from UK companies German outfit did a turnkey solution. Job went fine spec included gas heating from combi boiler and they fitted worcester 24's as parts would be easily available in the future.The site has mains gas and three meter points were installed by Transgas. German gas fitter, with Gas Safe registration, and I did check with Gas Safe because I thought it was a uk only scheme, turns out eu directive allows eu memebers to register. Building control happy all signed off , gas cert issued and letting commenced in 2014. With the build came an year one inspection and snagging, boiler serviced and another cert issued by same German engineer.
December 2015, written to by council asking if I would like to convert Holiday Let to full occupation to help them meet social housing target. Said yes duly converted planning permission and council wants to supply tennants. Great. As its a new tenancy thought better to get certs done now rather than 4 months in. Electrical fine, gas, well all I can say is I think I would have been spoken to better if I had just run a group of nuns over with steam roller.
The gas person basically said I had employed a criminal to install the boiler and that I was thoroughly bad . (version without the swearing) Condemned boilers on the spot said installation was dangerous and that foreigners were not allowed to work on uk gas. The german chap had duly filled in some forms with his registration number.....was told that this was a lie and should have checked. I said I had checked...incensed him more. He said boilers needed re plumbed for gas and fitted properly and I needed to pay him 3k for the privilege. Used own choice language to say no.
In the entire exchange I could not get a reason why the installation was sub standard or dangerous. This leads me at last to my question.
The Meter is fitted on the outside wall, the pipework, a one piece solid metal pipe that is pre-formed with a 90 degree bend and is covered by yellow plastic sheathing goes from the meter through the back of the meter housing through a plastic sleeve into the Cabin. Inside is a short ( 3') stub of pipe with a thread and attached to that is a connector pipe made of what looks stainless steel ribbed pipe. This connects to the boiler some 300mm from the pipe coming out the wall. The pipe size is about 24mm od but with the ribs it could be anything from 22 to 26mm. The pipe looks exactly the same as the one on the meter that takes the gas from the ground to the regulator. The bends to the boiler are all less that 90 degrees, sort of a flowing s shape. The pipe is held to the wall by two clamps.
Sooooo what is wrong with this...Have spoken to Germans they said that its fine it , just a standard installation pointed to photos , lots of them on the heating section of their website all look the same as mine. Tried Worcester, won't speak to me as I am not an installer.
All I need to know is what I need to ask for, if its wrong...and what price should I pay for 600mm of re piping. I know its gas but its not atomic zombie gas.. Given the gas chaps reaction I am a bit wary of approaching others without knowing what I am dealing with.
Area is wiltshire.
Any help or direction greatly appreciated.
Background.
Area is wiltshire.
