Currently in the process of putting in some 6”x 6” 9’ gate posts to hang two 6’6” x 4 ½’ wide gates. This will be at the front of my property for side access. As I will be putting one of the posts right on the corner of the house flat up against the brickwork, I am slightly concerned that I may possibly disturb the structural integrity of house, as it is around 1890 build with no foundations as such, built mainly on bricks splaying out under ground level, does anyone have experience of this, or a similar situation, I am very reluctant to raw bolt the post to the brick work as the bricks are of quite soft construction, and would make a hell of a mess if I wanted to remove at a later stage, or would possibly even blow upon tightening. Any pointers much appreciated,
Regards - Ian
Regards - Ian
