Geberit Toilet Frame - Slotted Channel
9 Aug 2019
In the uTube video for Geberit they show a slotted Channel that the top fixings hang off and the feet get clamped into. Is this slotted channel 41mm x 21mm unistrut?
Unistrut won’t work with Geberit DuoFix.
DuoFix has its own rail system, cost twice as much as Unistrut.
Just use timber battens screwed to the wall and then bolt the geberit fixings to that.
I use 3x2 and cut the supplied geberit hex screws to length, so they don't penetrate the other side of the 3x2 and push it off the wall/floor. You have to predrill first though as you've lost the tip of the screw.
