- Joined
- 17 Jun 2014
- Messages
- 3
- Reaction score
- 0
- Country
Hi, I have the above boiler. This morning I blasted the heating on to dry some clothes, I came home and theres no hot water. The boiler is flashing this code and says pressure is only 0.3
I reset it, and tried to use the filling loop to top up the pressure.. Thing is, when I turn the grey taps, nothing happens. I tried turning the valves beside the taps, the cold valve turns, the hot valve seems stuck. But here's the thing, it appears to be stuck on open?!
The screwdriver line is vertical, I.e in line with the pipe.
What can I try next? The valve really isn't shifting. Could the heat have fused it? Is vertical open? Is there some other kind of problem? Why is the filling loop not filling?
Thanks!.
Thanks!.
