Glow worm flexicom 30cx
may only be blocked filter on cold inlet or blocked dhw heat exchanger..
was it slowly getting worse
should i change plate exchanger or whats the best way of cleaning it.Thinking of labour costs verses part cost
you can take it out and clean it with a descaler eg kettle descaler. if you look at the boiler you have two screws what hold the unit and it pulls away sealed with orings
dont forget to drain first ;)
no done loads and there fine a little silicone lube helps (not silicon in a tube)
the lube like washing up liquid.
cheers gasandoilman for your help. i always used to replace them but now i will de-scale. Could i use any of the kamco range as a de-scaler
supose so but may be expensive i pour in kettle descaler in you see it bubble through and works a treat :LOL:
filling loop not turned off properly (plastic grey handle underside of boiler in the middle)
