GLOW WORM SPACE SAVER 38 GAS VALVE WANTED
19 Oct 2007
Liverpool
hi all
I am after a second hand or new replacement gas valve for the Glow worm space saver 38
the one i have is the white button version maclaren ITT but i have been advised that the later version with the blue button can be used
K9049 or K6466
I have had a replacement part sent to me from HSSSpares.co.uk (a honeywell) but the gas man has said it is not the right part ,it can be fitted but only only after making lenghty adjustments and then he cant guarentee it will work
does anyone have one to sell me or an old space saver boiler that the part can be taken from
thanks
Try this GWORM K9049 GAS VALVE (NOW 327300) GC 392767
This is what comes up on parts arena, but cannot find the new number given :confused:
have tried them they dont have and only show the part listed as being obsolete
Hi all
Just a little update another gas man came out and fitted the Honeywell valve.he needed an additonal pipe for the pilot light and its all working fine now
the only thing to note is that the bottom cover will not fit on the boiler now as the honeywell is larger than the original maclaren valve
so it doesnt look very good but who cares ive got hot water and heating
thanks for replies
I've got same problem. Can you tell me what the part number for the Honeywell valve you used was ? Cheers John
