Hi guys,
I'm after a bit of advice please.
I have a Glow-worm Xtramax HE boiler and a few months ago had an engineer replace the secondary heat exchanger for the hot water, quickly followed by the CH pump which sprung a leak.
We've also fitted a magnaflow unit to help clean out any rubbish floating round the system.
Everything has been working fine with the exception of one thing that has been happening for a long time.
When the DHW is switched on and in use the pump continues to cycle for about half an hour after the hot taps/shower have been switched off. This can cause problems with the heating as I assume the boiler thinks the hot water is still being demanded so the pump is diverted to DHW and the radiators are no longer fed.
Sometimes the burners will fire up and heat the DHW and the pump will cycle again even when not called for - in the night for example.
These problems stop if the DHW is switched to the 'off' position. We have therefore been operating our DHW by manually switching the water on when we want it.
Now an extra problem is happening.
When someone is using the shower and the DHW is being heated and used, several times an F14 error occurs (Flow temperature >95c) and the integrated hot water tank appears to dump its contents to the radiators. They begin to heat up even though the central heating isn't switched on.
The F14 fault can display 3 times for about 20sec and then continue normally during a 10 minute period of hot water use (shower).
We have changed 3 of the 4 possible thermistors just in case (not the one on the hot water tank)
Can anyone shed any light on these errors all during DHW operation:
- Pump continuing to cycle a long time after there is no call for it?
- Radiators warming up whilst hot water in use?
- F14 error message?
I'm having real problems getting hold of the engineer that fixed the problems before. He had suggested in the past to change the main control board and that 'may fix the pump over-run issues'. I wasn't keen to spend hundreds of £'s on trying something that MAY fix it!
If anyone has any views or thoughts, they would be much appreciated.
Many thanks.
Tim
Reading,
Berkshire
Many thanks.
Tim
Reading,
Berkshire
