Yes guys its me again (and its the same boiler),
Basically in CHW mode the boiler is firing up, rising up to temp rapidly and shutting back down again. When you turn on the hot water tap the boiler runs away merrily and provides hot water. Pump runs in both modes.
I felt the flow pipe below the DV and no heat is getting through (CHW). All heat seems to be getting diverted to the secondary Heat exchanger.
So i pulled the DV motor off and did a buzz test across all three terminals. No buzz. Im assuming this means the motor is burnt out??
I stuck the multimeter into the terminals off the lead and the only reading i got was about 43 Volts. Does that make sense??
It says in the manual that when you have the motor off then turn on a tap and see does the spindle move in and out. Try not to laugh too hard at this but where exactly is the spindle. I could see naff all moving in and out. The only spindle like thing i found was in the hole from where i had just removed the DV motor and it wasn't going anywhere!!
One final schoolboy error i may have made is that i have left the isolation valve closed!!! Only thought about this when i was driving home!!!! Will check it first thing. They werent your usual plastic handle type but basically a spigot with a slot in it. I left them in the vertical position. This was the position that the HW flow was in so im assuming that means open. Feel free to clarify!!!
I hope you enjoyed your cup of tea when reading this and it brought a smile to your dial!!!
Grill
Grill
