gravity feed radiator heated slowwwwwww.
27 Nov 2004
my system is:
F&E tank,
boiler gravity hot feed to cylinder and 2 radiators in both bathrooms.
a central heating pump for all other radiators in the house
no motorise valve, no cylinder stat,
but only a room stat.
I have drained down the system entirely today, but after i refill it, all the radiator on the pump system are hot, but the 2 radiator (gravity feed) in the bathroom doesn't.... my hot cylinder doesn't even heat up properly.
I have tried turned off both radiator and the hot water was only pushing slowly to the hot cylinder, but not good enough to heat it up.
i dont think there is an airlock.... all radiator are bleeded starting from the bottom one to the top.
any advice please?? what can i do?? :cry:
I would say that this is an airlock on the gravity circuit.
Do you have any other vents, either above the boiler or in the airing cupboard?
boiler is "potterton kingfisher II"
i have tried running some water out from the radiator, it slowly get warmer & warmer, but after i close the valve it goes back to cold.
i also loosen the hot inlet (from boiler) on the cylinder, there are no air and water comes out.
... there are no other vent on the gravity circuit or cupboard
there is only a drain valve near the bolier where it goes into the boiler and to the central heating pump.
The system was working fine before i drained it... :(
vern, follow kevplumb's advice - he knows what he's doing.
kevplumb said:
pull the stat no pump on
but be carefull ;)
wait for the rumble then put it back QUICK
then bleed the rads :cool:
pull the stat??? :eek:
could u please explain a bit more what u trying do?
Do i turn on both HW & CH then pull the stat off !?!
Could I just turn on both HW & CH, then turn the stat to min. temp? and wait for the rumble then turn it back on??
what happen if it doesnt rumble?
sorry for all the questions.......many thanks in advance!
pull the stat???
dont turn the pump on
take the thermostat phial out of the pocket on the boiler
you may need to remove a split pin
then light said boiler sit back and wait
it will rumble ;)
then bleed the air it has just pushed out
kevplumb said:
pull the stat???
it will rumble ;)
So i turn on both HW & CH and set the room stat to min. temp? or just turn on HW only?
pull out the thermostat phial out,
once starting to rumble, then put it back in.
what does this do to the boiler actually?
will it harm the boiler?..... i dont want to break it...
thanks
no put it on hw only
it will boil the water in the boiler
no it wont do any damage as long as you put the phial back
if you have msn log it in and get mine from my profile ;)
and i will talk you through it :idea:
kev, would it be prudent to point out to any other readers that this advice doesn't apply to all boilers, just in case they all go off and try it?
tis fun trying to do it with an apollo
now that does take experience and bottle
tends to be best with c/i heat exchangers
which most of the old systems have ;)
why do you think i asked the poster what the boiler was :LOL:
Haven't tried it with that.
Yup - I know ;)
Yup - I know ;)
I knew exactly why you asked, which is why I shut up and let you get on with it. I was just concerned in case some bright spark decided to try it with a non c/i h/e :eek:
