chrishutt said:
And how do you propose to control the CH circuit? And how will the boiler be controlled? You seem determined to ignore advice - well, that's your problem.
Thats a bit harsh, i am not ignoring advice? i am just trying to make it as simple as possible for me with everybody's help.
If i fit a 2 port valve on the gravity return and wire this to a cylinder stat, then wire the 2 port valve back to the pump, then tee the cold feed and vent, with all the helpful advice i have been given on here i would presume this would work?. The central heating will still be pumped by the circulating pump and the boiler will run off the programmer as normal, why wouldn't this work? as 2 or 3 on here seem to think it would.
All advice appreciated.
