GROUT
30 Aug 2005
Aberdeen
Hi Guys,
Would you recommend this bagged grout?
BAL SUPERFLEX WIDE JOINT GROUT, limestone colour?
The tiles are the same for the walls and floors, a sort of limestone colour, or would white grout look better? its a white bathroom suit.
Cheers
alan
Sure nothing wrong with that and it's a very high spec.
It depends on what shade Limestone you have, some of the lighter tones are better Suited by BAL Ivory which is few shades lighter than the limestone and is also available in wall and floor versions rather than just the wide joint floor version.
As far as I know BAl haven't produced a Limestone wall grout, or I've not be able to find it so far.
But aesthetically it's far better than white.
Fine for walls, it's a much higher spec than you require which is no problem at all.
You might find it a little messy to actually do, so get a quality grout float and take your time.
Don't allow it to dry for too long before you wash it, it contains additives to make it flexible, these additives are pig to clean off the tile surface once set.
So grout one entire wall then wash, grout a second wall, wash first wall again, then wash second wall. etc.
Should come up nice and clean.
