(Sorry if this contains a lot of info - better too much than too little!)
I have the following CH: Icos Ideal HE-18 boiler, 7 rads (6 with Honeywell TRVs, 1 - in hall - controlled by wall stat), Grundfos Alpha+ pump, Drayton cylinder stat and 3-port actuator. System is in three-bed council house and was installed 18 months ago.
Back in mid-January, I had a problem with what appeared to be a stuck actuator on the 3-port (no HW). Council's contractor came out and sorted it.
Since then, though, I'm regularly getting the following problem: once the system has been on for an hour or more, when the boiler burner kicks in, there's a distinct sort-of 'choking' sound from within the boiler. The boiler can also rattle a bit.
This seems to then travel within about 20-30 seconds through the pipes to the area around the pump/3-port/HW cylinder. There is then a series of loud noises from this area (worrying, as I sit in the living room right underneath it!). These noises vary from sounding as if someone is dragging a heavy bit of furniture around, to a sound which is like someone physically wrestling and wrenching the pipes at that point. It can even cause the HW cylinder to shake, and I'm sure this is not doing any of it any good at all (not to mention my nerves!).
From listening to the sounds coming through the pipes in the living room when it's doing this, it sounds to my untutored ear as if not enough water is going through the system, hence the 'choking' (see point 3 below, though) - but then, what do I know?
At other times, instead of or as well as this, there's a machine-gun-like rat-tat-tat in the TRVs on some of the rads. Also, turning the TRVs up and then back down to the previous setting (whatever it is) can produce the same gunfire) Then, at other times, the whole system seems to run fine.
These are the things I've tried so far:
1) Bled the radiators - no indication of air in any of them
2) Bled the pump (you know, that vertical pipe with the screw-cap on it) - no air there either
3) Changed the pump speed. Whichever it seems to be set to, it either doesn't cure it at all, or seems to cure it for a few hours to a day or two, then it's back in full Radiophonic Workshop mode.
Also (I don't know if this is relevant, but I'll ask anyway), how far around should the spindle on the 3-port be able to turn? Mine will only turn from about 10 o'clock to about 12 o'clock. The guy who came last week to do the annual gas safety check said that this was normal.
I'd be grateful for any advice on this, as it's shaking the s**t out of the system (and my nerves). As it's a council house, I would only be willing to do things like minor adjustments myself, but if I needed to call the Council's contractors in, I'd like to have some ideas as to possible causes.
Thanks in advance.
Thanks in advance.
