Hey what method can be used to set out the required fall for a gutter in there is no fascia board or anything level to measure the fall from. I plan on using a string line.
Put the line up and carefully hold a spirit level next to it. You will either have a fall or you won't!
600mm is quite a big fall. I'm sure you mean 60mm.
In my gutter bashing days I used to measure down from the front edge of the tile to work out a fall.
By pouring a bucket of water in the high end of the gutter I could check for discrepancies
